Yup, Mr.Physio mentioned it. I'll do what they say and hopefully I'll be back to work in no time.
It's amazing how little you can do when your legs are a no go.
I've had my ITBands stripped. Let me know what you make of it
When people talk about dumbbell bench press and the such are you referring to total KG or KG per dumbbell?
SLDLs - looking ok, but there is a slight extension in your lower back. If you aren't flexible to lift from the floor then put something under the plates so you can lift from "dead".
What weights have you got on there to make it 160kg? Not saying you're fibbing, it just looks like (and sounds when it goes down) about 80kg! Are the 2 big plates more than 25kg each?
if those SLDLs are 30kg more than what you thought your 5rm is and you did them easy, you have a rather fantastic 5rm SLDL!
whats your deadlift like?
Ok, well I've been to the doctors a few times with my lower back over the last year or so and he's told me to stop deadliftingTo be honest the only time my back hurts is when deadlifting/SLDL.
There is no pain I'm getting, It's more of a crushing ache across my lower back and down my left hip, I've tried everything to fix this from stretching and doing a good warm up before lifting using this work out for the last couple of months http://www.dieselcrew.com/lower-back-rehab-fix-lower-back-injuries .
Now after deadlifting or doing SLDL I've found it really hard to open my legs for bench press which would give me bad cramp this leads me to think It's a hip problem rather than a back one.
I've tried a belt which makes no difference, Would paying to see a sport physio be any help does anyone think? Do you think I should just take the docs advice and give up the lift?
I think not warming up when I first started has damaged me somehow also the fact I've spent most of my life in a chair and I just have a weak lower back.
Oh well done Andr3w![]()
They should be done from a dead stop really, particularly if going heavy. I've raised the bar up on plates before to avoid a small amount of extension from trying to go from the floor.from floor? i start mine from a racked position never lowering to the floor
That's because they add a fair amount of assistance to the squat. Wrap them up really tight and see how much heavier you can goEnded up buying some knee wraps instead of a support for that dodgy knee of mine, as it was 'buy 2 get 1 free' on Bodymax accessories when I was in Powerhouse getting a new dipping belt. Absolutely amazing the confidence that they give you on squats! Felt like I could have just kept adding plates all day. Will need to make sure that I alternate using them though, as I can see my legs getting much stronger than the knees which will no doubt lead to more problems down the road.
