OcUK Minecraft Server - Rules & Chat
woop back up :D
[EDIT]
And back down again :(
[EDIT]
and back up again :p
screw this can't keep repeating myself. It keeps restarting lol. I think bukkit finally caught up with the admins lol
woop back up :D
[EDIT]
[EDIT]
Looks like craftbukkit is clogging up the system after a while, are scheduled restarts still only every 24 hours?
ok so syl here are plans.
Black is what we already have red is new stuff.
the two side stair cases will be extended forwards but flat not going down.
once they are far enough ahead that the middle stair case is below them then we'll reads the centre tunnel to them too. so it's back to the 3 arches.
then around the tube that makes the occulus (which will be glass at this level) we'll make a round room that will have an inner ring of pillars (basically the room will be formed by 2 of the corridors we used so there's be a ring of pillars where that inner red circle is but not a solid wall) an another set on the walls with arched roofs between.
on either side those two big red rooms will be attached.
one will be a large warehouse/furnace room, the other might be a tree farm/furnace room/more storage or farm or cactus or sugar cane etc.
then the massive room on the right will be the main welcome chamber plans for that are on going.
Is the server up and running? and if it is, what's the IP?
Sorry, 6am and i've had zero sleep. Just noticed on the first page :S.
Hey guys,
Would one of the admins mind putting me on the whitelist?
Seems French is away at the moment :)
Linktart name: aaron
Minecraft name: aaron955
Cheers, much apreciated. :D
have you registered on the site and put your name in cause i can't see you there to add.
sign up on linktart.co.uk
join the minecraft group
in the group go to minecraft server and register.
