Cleeecooo, the only thing you seemed to have missed off both lists is a pump top for ddc pump.
I need a pump top as well?
**** me!
Can you recommend one?
It generally doesn't make much difference as long as the reservoir is before the pump. Just whatever makes the loop look the cleanest.k thanks. How should the loop go? reservoir - pump - rad - CPU - GPU(later) - Pump???
Filling is easy, Fill the reservoir up, Power up system for a couple of seconds, power down so the pump doesn't suck on air, Refill reservoir, rinse and repeat.
Best to do this by only powering the pump up, same goes for leak testing.
As for emptying it -haven't perfected the art of that so I can't really offer any advice that doesn't get water all over the floor![]()
**** me!
Look for an EK-DDC X-TOP V2 G1/4.
Pump top? As far as Im aware they change the fittings to ones more commonly used in watercooling.
thanks.
What exactly does a pump do?
i find slim rads are a waste of time.......
nope you would be surprised i had a tripple thin RAD and it worked great all depends on what fans you use.
3) Why would RJKoneill rather use sello tape instead of compressional
I hope to fit a 360 and a 480 rad in the bottom.
