Think how great it's gonna look with decent AA. Loving some of the fight animations, so detailed.
I can't stop being concerned that CA will screw the performance up after all and Dx11 will be a power hog
Very easy, the unit cards are pretty self explanatory, I'm sure with a bit of practice you'd pick it up.
I only have about 8 provinces, taking a castle is the hardest part in the game for me. The easiest thing is to lay siege and force them out but this can take 5 turns. I have noted the following, defending archers when at the edge of the fort have a massive advantage because they have cover. When going through the doors it is VERY easy to get pinned in by defending melee so your army will be stood outseide like plumbs. Yours troops fall when scaling the walls, generally go for shorter walls if you can to reduce casualties. Its hard you need to find a weakness to exploit, generally you need to attack from multiple angles to get some units in the compound.
Generally though unless they have no archers i just lay siege
Really should go through the tutorial I think. The last Total War I played was M2 so things have changed a bit. Also in M2 it was kind of obvious what each unit did just by the name (certainly as england) but with this none of the names mean anything to me so I have to keep looking at the details.
I love all of the time periods that focus more on melee combat and loved Rome/M2 so should love this too. I just seem to think war games lose something when gunpowder becomes widely available.
had 5 provinces out of 25
I suck
