ump combo i find slim rads are a waste of time.......
The thickness of a rad is virtually irrelevant, the only advantage a thicker rad has over a slimmer rad is a reduced pressure drop. Theoretically there is no reason why a thin rad cannot transfer heat at the same rate as a thicker radiator, and there are a couple of thin radiators that prove this rather nicely.
Such as?
I omit things like the BI stealth rads as they are so thin that the increased pressure drop does affect performance
^^^^^^ How did you come to that conclusion? The design of the GTS is with low pressure loss in mind.
I stand corrected. I could have sworn I saw a radiator round up with the stealth, but on searching I cannot find one, so it's performance remains unquantified. Chances are even in the worst case scenario it wouldn't perform more than ~10% worse than the 'best' radiators.
So the slim rads are just as good?
I'm tempted by the Black ice GT stealth and getting a 480 and a 240 for that so i have a bit more room for my cable mess!
How should i go about spraypainting my case? Or shoukd i ask this in the general HW?
Whats the difference between powder coating and spray painting?
Well to get your case powder coated you will have to dismantle it and send it off to a powder coating company as the process can't really be replicated at home.
With spray painting it could potentially be quite difficult to get a good finish if you do it yourself.
Theres me thinkin i just go to b and q and do everything at home
Mire research is needed![]()
