Many people criticised the latches on the sides for making the case look less sleak but I assure you they are needed. There isn't a huge amount of room behind the motherboard tray but because of the way the doors close it doesn't really matter and they have made building a lot easier as a result.
There is a hole in to the back top right of the case which allows the USB3 cables to be threaded all through the case with relative ease and plugged into the back ub3 ports so it is not such a problem, however it does still mean you have extra cables in the back than you might want. So that is your choice, but it is possible.
The case is well put together, 100% sturdy and feels top class like my previous lian-li case did. You would expect it to be heavy as a result but given it's size it is quite light. It is however a dust magnet, particularly the window, so be careful to keep it clean. Though this is my first windowed case so that might just be normal.
The huge grate in the top would look great with a lighter back light under it. My motherboard has some blue lights on it for some reason (no idea why) and it is just lightly accenting the top fan and it looks quite good.
Let me know if you have any further comments.
