Care to tell us what the item is?![]()
Gee how did I not think of this....
Not sure what this is exactly, but it's nothing to do with shares/stocks.
Because the sensible solution is to write IOU £600,000 on one piece of paper and send that.
Your best option, if this is not a scam, is to act as an agent between buyer and seller for a fixed fee/percentage.
This negates the need for you to have capital or investors, both of which you don't have.
As long as it is contractually agreed (you have £1000) between all parties then you will make some cash.
Mixing up white power with cutting agents?
Problem is there is NO need for me in this deal at all, I'm trying to cut in on what will happen in a short amount of time when some information is available. Thanks for the suggestion though.
Haha, I wish. Ah well.
Because the sensible solution is to write IOU £600,000 on one piece of paper and send that.QUOTE]
Yeah but he'll look after it really well, if you send 600,000 x £1 IOUs he might lose a few and save you some money.
You might have left it a bit late raising the funds if its gone tomorrow![]()
(So how do I only quote some of a previous post, looking above suggests that I got it wrong)
That was a bit of an exaggeration, I was just highlighting that it's got a limited timespan before it's clear as the world to see.
I know everyone says it, but the deal is as waterproof as it could ever be.
I WISH I had the cash haha.
If the plan was that watertight then you would raise it through family...
I smell BS![]()
I smell BS![]()
Maybe not, he aint got time for people to re mortgage etc has he.
Tell me something OP , this thing you want to buy for 600k, does it have a value if your intended buyer falls out of bed?
