Question
Have level PhysX are you using? They might have an impact on the frame rate, and the Physics might be running on the CPU instead of the graphic card I think. Best check your settings.
PhysX is off.
EDIT: It was not off. While PhysX is off, I get normal 100FPS etc, but even with Medium it drops to 30's. Whats up with that ?
PhysX is off.
Unfortunately enabling PhysX effect significantly reduce performance (aka much lower frame rate). Mafia II is one game that really benefit from a dedicated PhysX card (an extra Nvidia card just for running PhysX).
With a single card, you should probably keep the PhysX level as low or medium, or even leave it off entirely if you prefer higher frame rate over fancy PhysX effects.
Something that you might be interested in reading:
http://www.tomshardware.com/reviews/nvidia-physx-hack-amd-radeon,2764-8.html
