VMware Linux bigadv
18 Oct 2004
Cumbria
Same here - that's why WMware peaked my interest.
Looks like I may have resolved my stability issues too - not had any lost work for 24 hrs - pity it's too late as I've just been STOMPED.......
Didn't even get a parp..........
Well, Delboy, you have 11 hrs notice to get another 60k points - otherwise please make sure not to mess up my cell.......as I'll be moving back in.
Edit: Well, looks like the deed is done - Delboy has upped his game and got the extra +60k......I don't think I have enough firepower to catch him again :(
10 Sep 2003
Got lucky, both my bigadv rigs dropped today, the next day or so may look a little lean in comparison.
The dual xeons are only 2ghz 4 cores (5405's I think) so only give me an extra 10-11k ppd on smp, I can't put the VM image on there as its being used for Hyper-V so VMWare does not run - not that I think it will even cope with Bigadv tbh. Oh well, it all helps!
...belated parp!
23 Nov 2002
Near Bristol
Man I'm getting some rubbish units, strangely more so that with the windows client. At least I got a 6901 today though, rather than the raft of 2684s I had been getting.
Everyone got the new 1.6 image running?
11 Aug 2003
Taunton, Somerset
Not yet
Haven't looked at the new 1.6 image yet - can you post a download link please.
Still working on getting a stable 4GHz overclock (told you I'd regret trying it) when I can find the time - had to update my BIOS to get anything above 3.8GHz. I seem to be stable at 3.9GHz but My temperatures are breaking the 80ºc barrier so when I've had a chance to give my H50 a clean I'll get back to finding a stable 4GHz
18 Oct 2004
Cumbria
Mine seems to be running ok now - had to drop oc to 4.2ghz (bit of a hash job - just not got the time to do it properly).
Had a couple of slow units but things seem to be back on track now - got a 6901 giving me 39k ppd.
23 Nov 2002
Near Bristol
Seems more stable to me
Can't say I've noticed much difference, bar the easy of setup for Langouste.
Btw that 920 OEM you sold me with the P6T and Gigabyte board, how well did it clock for you? Seems a decent clocker, currently doing 4.2GHz @ 1.325v Vcore / 1.3 QPI. It is LinX stable but not tested it under Folding@Home yet.
Cheers, downloading now :)
NP!
23 Nov 2002
Near Bristol
Ah all up and running again and I get a 2684 :(
Yeah I've had a fair few, I wonder if turning on Adv Methods would help get some different ones? lol
Dekez: All good science :D
Speed: I can't remember sorry mate, old age and alchohol :)
No worries, its a decent chip thats for sure. One of the better ones in my "collection" anyways. :rolleyes:
I just swapped it for another and it required a fair bit more voltage to hit the same speeds and be LinX stable.
23 Nov 2002
Near Bristol
Hmm, not sure the new 1.6 image has Langouste working right, it keeps failing to upload the work unit and getting stuck downloading a new one! :confused:
Might have to disable it.
Code:
[19:34:40] Completed 500000 out of 500000 steps (100%)
[19:34:40] DynamicWrapper: Finished Work Unit: sleep=10000
[19:34:50]
[19:34:50] Finished Work Unit:
[19:34:50] - Reading up to 3711648 from "work/wudata_01.trr": Read 3711648
[19:34:50] trr file hash check passed.
[19:34:50] edr file hash check passed.
[19:34:50] logfile size: 57616
[19:34:50] Leaving Run
[19:34:51] - Writing 3804824 bytes of core data to disk...
[19:34:51] Done: 3804312 -> 3526173 (compressed to 92.6 percent)
[19:34:51] ... Done.
[19:35:02] - Shutting down core
[19:35:02]
[19:35:02] Folding@home Core Shutdown: FINISHED_UNIT
[19:35:04] CoreStatus = 64 (100)
[19:35:04] Unit 1 finished with 95 percent of time to deadline remaining.
[19:35:04] Updated performance fraction: 0.949818
[19:35:04] Sending work to server
[19:35:04] Project: 7131 (Run 0, Clone 37, Gen 51)
[19:35:04] + Attempting to send results [April 14 19:35:04 UTC]
[19:35:04] - Reading file work/wuresults_01.dat from core
[19:35:04] (Read 3526685 bytes from disk)
[19:35:04] Connecting to http://128.143.199.96:8080/
[19:35:04] - Couldn't send HTTP request to server
[19:35:04] + Could not connect to Work Server (results)
[19:35:04] (128.143.199.96:8080)
[19:35:04] + Retrying using alternative port
[19:35:04] Connecting to http://128.143.199.96:80/
[19:35:04] (128.143.199.96:80)
[19:35:04] - Error: Could not transmit unit 01 (completed April 14) to work server.
[19:35:04] - 1 failed uploads of this unit.
[19:35:04] Keeping unit 01 in queue.
[19:35:04] Trying to send all finished work units
[19:35:04] - 2 failed uploads of this unit.
[19:35:04] Connecting to http://130.237.165.141:8080/
[19:35:04] (130.237.165.141:8080)
[19:35:04] Connecting to http://130.237.165.141:80/
[19:35:04] (130.237.165.141:80)
[19:35:04] Could not transmit unit 01 to Collection server; keeping in queue.
[19:35:04] + Sent 0 of 1 completed units to the server
[19:35:04] - Preparing to get new work unit...
[19:35:04] Cleaning up work directory
[19:35:04] + Attempting to get work packet
[19:35:04] Passkey found
[19:35:04] - Will indicate memory of 3072 MB
[19:35:04] - Connecting to assignment server
[19:35:04] Connecting to http://assign.stanford.edu:8080/
[19:35:04] Posted data.
[19:35:04] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[19:35:04] + News From Folding@Home: Welcome to Folding@Home
[19:35:05] Loaded queue successfully.
[19:35:05] Sent data
[19:35:05] Connecting to http://171.67.108.22:8080/
[19:35:16] Posted data.
[19:35:16] Initial: 0000; - Receiving payload (expected size: 24823612)
Code:
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54302
Thu Apr 14 19:35:04 2011 PID for socket: 746
Thu Apr 14 19:35:04 2011 PID 746: issending: 0
Thu Apr 14 19:35:04 2011 ===> PID 746 is (most likely) contacting WU server, content length: 3527197
Thu Apr 14 19:35:04 2011 ===> Helper pid: -1
Thu Apr 14 19:35:04 2011 ===> PID 746: numcores: 0
Thu Apr 14 19:35:04 2011 ===> now: 1302809704, last helper launched at: 0
Thu Apr 14 19:35:04 2011 ===> Launching helper: '/proc/746/cwd/langouste-helper.sh' (exe name: '/usr/local/fah/fah6')...
Thu Apr 14 19:35:04 2011 ===> Forked 1088
Thu Apr 14 19:35:04 2011 (0) Local: received 16384 bytes, sent 0 bytes
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54303
Thu Apr 14 19:35:04 2011 ===> now: 1302809704, last helper launched at: 1302809704
Thu Apr 14 19:35:04 2011 ===> WARNING: can only launch one helper in 2 minutes (per client)
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54304
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54305
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54306
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54307
Thu Apr 14 19:35:04 2011 Accepted connection from: 127.0.0.1:54308
Thu Apr 14 19:35:04 2011 ===> PID 746 is contacting main assignment server
Thu Apr 14 19:35:04 2011 (0) resolving 'assign.stanford.edu:8080'
Thu Apr 14 19:35:04 2011 (0) Connecting to: 171.67.108.200:8080
Thu Apr 14 19:35:04 2011 PID 1088 (child) exited
Thu Apr 14 19:35:04 2011 (0) Connected.
Thu Apr 14 19:35:04 2011 (0) Local connection closed (bsize: 0).
Thu Apr 14 19:35:04 2011 (0) Local: received 559 bytes, sent 396 bytes
Thu Apr 14 19:35:04 2011 (0) Remote: received 396 bytes, sent 559 bytes
Thu Apr 14 19:35:05 2011 Accepted connection from: 127.0.0.1:54310
Thu Apr 14 19:35:05 2011 PID for socket: 746
Thu Apr 14 19:35:05 2011 PID 746: issending: 0
Thu Apr 14 19:35:05 2011 ===> PID 746 is (most likely) contacting WU server, content length: 512
Thu Apr 14 19:35:05 2011 (0) resolving '171.67.108.22:8080'
Thu Apr 14 19:35:05 2011 (0) Connecting to: 171.67.108.22:8080
Thu Apr 14 19:35:05 2011 (0) Connected.
Thu Apr 14 19:36:04 2011 Accepted connection from: 127.0.0.1:54312
Thu Apr 14 19:36:04 2011 PID for socket: 1103
Thu Apr 14 19:36:04 2011 PID 1103: issending: 1
Thu Apr 14 19:36:04 2011 (1) resolving '128.143.199.96:8080'
Thu Apr 14 19:36:04 2011 (1) Connecting to: 128.143.199.96:8080
Thu Apr 14 19:36:04 2011 (1) Connected.
Thu Apr 14 19:36:33 2011 (1) Remote connection closed (rbsize: 0).
Thu Apr 14 19:36:33 2011 (1) Local: received 3527318 bytes, sent 615 bytes
Thu Apr 14 19:36:33 2011 (1) Remote: received 615 bytes, sent 3527318 bytes
Thu Apr 14 19:36:33 2011 (1) Ratelimit: sent 3527318 byte(s) in 28.410 seconds, 124157 Bps (121.24 kBps)
Man of Honour
OP
30 Oct 2002
Surrey
Ignore it its working according to Linuxrouter when I asked the same q. I het the same thing and its definitely uploading ok
23 Nov 2002
Near Bristol
I thought as much, the problem is it gets stuck downloading the new unit, so it is no good at the moment. I've disabled it, if I get the same problem with FoldingTwo I'll have to look into it more.
Man of Honour
OP
30 Oct 2002
Surrey
Mate your talking about a period of a few minutes between it finishing and it sorting itself out, thats nothing compared to the 30+ minutes it would take to upload the file without it.
