my min fps is 44% higher than your best min fps, while it's just pushing your vram to the edge.
So your min FPS is 0.44 x 9 + 9 better = 4 FPS more for 13 FPS total?
What do you want for that, a medal or a blue peter badge? The game would still be unplayable with such a low FPS, and I already stated several times that 2 Gb Vram only makes a difference of a few mostly unnoticable FPS over 1 Gb ram, and you simply prove that with your absolutely amazing (to you only) 13 FPS minimum on your 2 gb cards.
Also I dont see your results anywhere, and you never asked me to run the menchmark fully maxed out, nor specified what settings to use:
Post your results of metro2033benchmark.exe then.
I did that at your request, and all you do is whinge and whine. Do you really think that anyone else here is taking you seriously? Because no one seems to be believing anything you say about the issue of Vram.
TBH arguing this point with Raven was more interesting than it is with you, I want Raven back to argue about 2 Gb Vram with, not you.
