My friends pc recently starting to play up getting bsod. As nothing had changed and it was completely random I thought I'd check the memory hadn't gone bad.
Anyway, it would seem both a stick and a slot has gone bad With two sticks in (it's 2x2GB), memtest instantly fails with a stream of red errors
 With two sticks in (it's 2x2GB), memtest instantly fails with a stream of red errors  .
After checking both sticks one of them appears to bad. With that stick in, the red errors are there, with that stick removed, there is no problem. How ever if I take the good stick and put it into slot 4 the pc refuses to boot The sticks were originally in slots 3&4, the bad stick was the one in slot 4 and the pc refuses to boot with the good stick in slot 4
 The sticks were originally in slots 3&4, the bad stick was the one in slot 4 and the pc refuses to boot with the good stick in slot 4  .
So with the good stick alone in slots 1-3, pc boots and is fine. Good stick in slot 4, no boot, good stick and bad stick in any config, boots but bsod and errors on memtest .
So has the slot died and damaged the stick that was on there? or did the ram die and damage the slot? or is there something else I could be missing before he rma's it? Seems really unlucky for the slot and stick to die
Ram was corsair value ddr3 in an asus P7P55 with an i5 760
.After checking both sticks one of them appears to bad. With that stick in, the red errors are there, with that stick removed, there is no problem. How ever if I take the good stick and put it into slot 4 the pc refuses to boot
.So with the good stick alone in slots 1-3, pc boots and is fine. Good stick in slot 4, no boot, good stick and bad stick in any config, boots but bsod and errors on memtest
.So has the slot died and damaged the stick that was on there? or did the ram die and damage the slot? or is there something else I could be missing before he rma's it? Seems really unlucky for the slot and stick to die
