Portal 2 Collaborative Disposition Test
1 Jul 2009
Your Aperture Science Cooperative Testing Type is:
Atlas
Brave and up for anything-you like adventure and nothing scares you. You value friendship highly. Your ideal cooperative partner would be inquisitive and sensitive.
Glados
Imperious, highly intelligent, impossibly cruel-you wield your intelligence and wit like a cudgel, bludgeoning those around you into passive submission. Keep an eye out for cooperative test partners with low self esteem and body image issues.
Ratman
You're the quiet, artistic type, happy to ponder the solution to a puzzle in quiet solitude. Compatible cooperative test partners include introspective loners, deaf-mute invisible people, and mannequins.
FFS :mad: :( :D
Weighted Companion Cube
Stalwart and dependable, you're always willing to give a friend the shirt off your back, a shoulder to cry on, or a step up. Compatible cooperative test partners include shirtless people who can't stop crying while they use you as stairs.
Chell
Resolute and tenacious, you won't quit until a puzzle's solved. Your inability to give up against impossible odds makes you a bad match for cooperative test partners who give up against any odds at all, racing to the internet for answers.
Chell
My Aperture Science Cooperative Testing Type is: P-Body
Inquisitive, sensitive-you analyze situations and approach problems with care. You value friendship highly. Your ideal cooperative partner would be brave and up for anything.
Glados
:p
Glados
Wheatley
Funny, high-strung, a bit of a motor-mouth-these are the words people would use to describe you when they're not telling you to shut up. Your ideal cooperative test partners include people who won't mind you bumbling around breaking things while they do all the work.
P-Body
Cave Johnson
You don't see crises-only challengitunities you choose to scale like mountains. You're a can-do, shoot-from-the-hip, silver-tongued self-starter. You're a good match for any cooperative test partner, providing they shut up and listen.
And here's what Cave looks like:
