Are we ever likely to need more than 4gb for gaming?
23 Dec 2009
RG8 9
within the next couple of years anyway.............
Just wondering as RAM prices are really low at the moment. I paid over £100.00 for 4gb of Corsair XMS3 this time last year and I can bag 8gb in 4gb sticks in the current easter OcUK deals for £60 odd..
Is there any point?
If Windows 7 64 bit is going to be the minimum requirement for Battlefield 3, I see no reason for them not to start coding to really take advantage of more than 4gb ram now that the 32 bit platform has been dropped.
Games that stream data from disk would see a real benefit if they started using more ram.
So possibly yes, in which case whilst RAM is cheap, I should buy now?
AMD setup. looking at this - http://www.overclockers.co.uk/showproduct.php?prodid=MY-053-GS&groupid=701&catid=8&subcat=1516
It should run ok no? Would look sweet on my crosshair IV. :D
Decisons decisions......
I Just bought 4GB Corsair Memory DDR3 1600 but it was only an extra £30 to double up for 8GB, but yeah i didnt think id ever have use for 8 so i just took the extra £30 and went to a match and bought a bevy :)
I might just get it in. Won't hurt, will look cool and I can always sell mine for a bit.
Will that RAM I linked to work on my AMD setup no problems?
It's one of those crystal ball moments. You may be smart and benefit or it may not do anything for your performance and is made obsolete by DDR4 before 8GB is required. I'm building two new pc's one with 4GB and the other with 8GB, think I have it covered ;)
Is there any point?
i asked myself the same question when contemplating the upgrade of my Amiga 500 with an extra massive 1/2mb....
future games and apps will always need more.. and more.
Is there any point?
I am thinking the same, out of interest what version number is on your XMS3 you have
Is there a significant different between different speeds between RAMs, DDR2 and DDR3 in terms of real life performance (games, multitasking, rendering) and not synthetic benchmarks.
I will come back to you on that one as not at home at the moment. :)
Good question, I would also like to know this.
I seem to recall a developer giving an example of what they use / need as a test rig. The memory was around 12gb (some years ago now, two or three).
The next rig I buy will ideally have at least 8.
I bought an additional 4Gb only to find my mobo would not overclock with 4 sticks of RAM in...sold both kits and bought 2x4gb sticks, its so cheap at the moment there is no reason not to go with 8Gb.
In general the answer might be no as most people arent using 64 bit OS so more then 4 isnt in the script
But Ive found over 4 can easily be used and therefore useful if you include all the extras that go with a new game.
So the biggest one is texture memory, this is main memory used where the graphics card overflows.
Then theres the OS, in theory you can swap out unused programs to the pagefile and its not a problem but to do that every time you load the game or even alt tab is a pain and laggy till it completes
I used to play bf2 with 512meg so the above is possible but its horrible, avoid the pagefile always if you can
Then there is teamspeak mumble fraps or other gaming programs. More then 4 is going to be useful right now (and you need the 64bit os obviously) but not essential
Finally I find windows tries to cache everything, really saps spare memory. If you have nothing spare or free mem is low - your chances of it churning away juggling programs increases, which you means you wait and/or lag.
You can get lucky like my bf2 example but windows typically is a pain to use on the edge, space to breath is best
I say this as someone who went from 2 to 4 to 6 now since Xmas. Ive switched from ddr2-5300 to 8500 then ddr3-12800 Those numbers relate to peak transfer rate in MB apparently
So Ive more then doubled the memory speed and I'd still say its all about the hard disk mostly (get SSD).
Thats way more noticeable then memory everyday especially if you are using the pagefile at all.
So in order of noticeable gains, its how much not how fast.
Speed up the hard disk, dont use the page file by always having enough memory space and then finally worry about your memorys bandwidth and all that benchmarking stuff.
http://www.thebuzzmedia.com/ddr2-800-vs-ddr3-1333-does-speed-matter/
I put a SSD onto a 7 year old build, 200mhz DDR1 and its a great improvement
