antec 300, PSU mounting?
22 Sep 2008
on the antec 300 case, would i mount the PSU upside down so the fan is facing upwards, or mount it as normal so the fan is blowing in to the floor of the case?? :confused:
As long as the case has ventilation holes and some kind of filter so clean, cool air can be sucked into the PSU then yes. If not then I'd mount the PSU upside down.
I've heard you can mount it the normal way up because it's got a big gap between the PSU and the floor, but mine's upside down and I'll be leaving it that way.
It can be done either way, mine in my antec 300 has the fan facing down, only due to the psu being about loud with the fan facing up, but my overall system temps lower quite abit with the psu fan facing up.
Basicly its which ever is best suited to ur psu, both cable and fan.
Errr, seems i somehow replied to the wrong thread :s
Weird I had a thread I created which had a similar topic, nevermind!
