Fan Power Outside Case
25 Feb 2011
North East
I'm just speccing up a computer for someone, the only problem is that the computer fits in a very small cabinet and there is no ventilation. I was going to just drill a couple of 120mm holes in the cabinet but I've just had an idea to use fans to intake and extract air, is there any neat/safe way to get a power connector out of a case to power an external fan?
Run a molex through a watercooling grommet hole, if it fits through the hole.
Failing that grab one of these and use some extensions
http://www.overclockers.co.uk/showproduct.php?prodid=CB-030-AK&groupid=1929&catid=153&subcat=
Or get one of these, remove one end and attach to two wires on each of the red and black wires on your fan.
http://www.overclockers.co.uk/showproduct.php?prodid=CB-051-AK&groupid=1929&catid=153&subcat=
Loads of possibilities really.
You could even power the fans off a 9-12v power supply if you have one handy. An old modem/router power supply would be perfect. Just needs a bit of custom wiring.
