Hi, from looking around on the net I’ve seen some debate on what temperature to check from on the Phenom II's. I thought that on HWMon i should be reading off the core temps but others say to look at the CPU temp I just want to clarification on this.
Currently running a 1055t with a 3.6Ghz OC Temps below. - Cooler is a Akasa Venom
. Considering the max temp on prime is around 60C and it never goes that high during gaming the current OC is OK right?
