Project - Blueberry
26 Dec 2009
North
Hey, new project started so thought i should share.
Any thoughts, inputs and recommendations welcome :)
Spec List: -
Lian Li PC-V354b
Intel i7 2500K
Antec Kuhler H20 620
Asus P8p67-M Pro
8GB Corsair Vengeance (Blue)
OCZ 120GB Vertex 2
1TB Samsung SpinPoint
Gigabyte GTX 480 SOC
Corsair HX1000W PSU
4 x 120mm Alpenfohn Fans
1 x 140mm Alpenfohn Fan
Heres some stuff i recieved a couple of day ago and some unboxing pics
and the SSD that was recieved a couple of days later, kind of regretting not waiting for the vertex 3 but at £140 cant really complain.
The heatsink on these are really tall, may be an issue with the larger coolers
A few shot of the board
With fans fitted, looks uber beastly :)
and the case itself
Sorry if i over done it with pics, got a little carried away!!
Only problem with it set up like this is that the antec kuhler 620 is blowing hot air directly onto my gpu raising temps in the high 90c's in furmark. So what im doing is cutting two 120mm blow holes dirctly underneath the graphics card @ the bottom of the case alowing the pgu to suck cold air into it.
I might also mount antec 620 into the rear with some slight modding but i think it looks better in the front, anyhow see it goes.
ok theres no going back now!!
Marked out
scored, went round about 8 times with a 409
Cut with the carbon fibre reinforced disk
quick sand and gone over edges with a black marker
Pritty pleased, didnt want to spend to long as this will be unseen. Little upset at cutting joles slightly too big. Used the outer ring of the fan grill to mark but on reflect the 2nd last would have been better.
Nice work on the cutting, although I think you could've reversed the airflow in the case because I think Antec actually say that their all-in water units actually work better as exhaust (unlike the previous Corsair models).
But still, having the Kuhler up front looks better as you say.
