- 24 Apr 2011
Hi everybody!
Just registered in your forum since i saw some good threads already and found them quite helpful, i am glad of being part of it now.
I would need your help with something that is burning my brains.
History:
1-bought msi hd 6950 (modded with hd6970 bios)= incredible performance.
2-at the same time had different problems/circumstances:
a) one day by mistake i unmade the cpu overclock then i restored (e8400 3ghz @ 4 ghz)
b) started to play with Afterburner,osd monitoring,etc..(to see gpu temp)
c) changed the msi ventilation and installed the thermalright shaman (amazing performance....full below 50º)
The problem was that i realised that now, crysis 2 was working between 29-45 fps in extreme at 1920*1080, when before it was between 45-60 fps average)
Obviously i started with the paranoia, and tried many things: drivers 11.3 / 11.4 / windows format / etc..checked the cpu oc / and then i realised about 2 things:
1) gpuz shows the core and memory freqs but in sensor it reads everything fine but in VREG temp it keeps all the time at 254.5º obviously this is not real...but cannot change that value (even i restored with another 6950 bios)...everything changes but that.
2) with the afterburner i can see that the core freq although i can change it,then in monitoring i can only see MAX 500mhz...so i think that could be the reason of my drop performance now,right??
i have read many threads about that i unchecked the flash hardware acceleration...no youtube videos running...just a new windows 7 64 bits sesion...and start the game...but stucked at 500mhz...
I would like to request all your help please!
PD: i can change the core values and they will be shown in CCC /AFTERBURNER / TRIXX and ASUS smart doctor perfectly but when playing it keeps the freqs maximum at 500mhz.
History:
