HI
im looking to build a new system i will mostly be using it for 3d max, CS4 and other graphics applications and occational games.
i already have a case a Coolmaster Stacker STC-01
• Motherboard - Intel Hunter Cove DH55HC H55 Socket 1156 DVI VGA HDMI Out 8 Channel Audio ATX
• Processor - Intel Core i5 750 2.66GHz Socket LGA1156 8MB L3 Cache Retail Boxed Processor
• Memory - Corsair 4GB (2x2GB) DDR3 1333MHz XMS3 Memory Kit CL9 unbuffered
• HDD Western Digital WD3200AAKS 320GB SATAII 7200rpm 16MB Cache - OEM Caviar Blue
• Graphics Card - PowerColor HD 5770 PCS+ 1GB GDDR5 Dual DVI HDMI DisplayPort PCI-E Graphics Card
• Power Supply - OCZ Stealth Xstream II 500W PSU - 3x SATA 1x PCI-E
could anyone off advice if this would be ok, or if i should improve anywhere. budget is 600-800.
thanks for all the advice
