The 102.4 are really nice speakers. They deserve something a bit more upmarket that the Technics... but what is your budget?
Hi mate,
I'm looking to sell my Arcam A70 which will be perfect for your kefs![]()
That's not going to be easy or cheap. How many sources of each signal type?, and how many sockets of each type on your TV?another question: what can i use to get scart and hdmi inputs and get a single output of a hdmi for my hdtv.
I've had Kef Ref 102s in the past, which were of a similar age, and found the big rotel power amps were well suited and had the grip and current delivery to keep the bass nice and taut.
I got the impression that the kefs like something with balls and that's fairly upfront. I spotted a tact 2175 recently going for around £500. Might be worth considering.
thanks, the price of the rotels seem to be in my budget. What rotel model should i look at ? ROTEL RA03 is the one i've been looking at.
Yes, you'd need a pre-amp of some sort to switch inputs and control the volume. Suggestions would rather depend how many inputs you'd want to switch, and if you'd be after remote control. It could be as simple as an potentiometer/attenuator in a box.
