there's a difference?
I was using the '/' to denote a fraction. e.g.
____6___
2(1+2)
You see, the problem with that is that you've included spaces which weren't in the original equation which makes it what you want it to be![]()
____6___
2(1+2)
ahh, you make a very good point there
And the cycle returns...Seriously, for the number of people to vote for 1, I worry for the educational standards of this country. Come on it's really not that hard is it?
There is no right or wrong answer. It's all in the interpretation of the expression which is inherently unclear.
I'm afraid there is a right and wrong answer.
I'll admit that I skipped about 12 pages here but surely we've all been to school?
Well basically all of this has been covered multiple times, but the 'ground rules' applied in primary/secondary school for the ease of young minds negotiating mathematics aren't universally applicable and those that have experienced third level education or even professions in mathematics have said that the equation can be legimately interpreted in two ways.I'll admit that I skipped about 12 pages here but surely we've all been to school?
I'm afraid there is a right and wrong answer. It's fairly clear which is the accepted priority here. At least it was in the 70's when I was at school.
Another way of looking at it would be how it'd appear on an exam paper, though that's probably been mentioned. Converting from a fraction format to a line format shows, again, that the structure suggests the answer is 1:
6(1+2) = (6÷2)(1+2) or 6(1+2)÷2 = 9
2
6____ = 6÷2(1+2) = 1
2(1+2)
If the original equation were given to represent the first instance, there's no way it'd make it onto a final paper draft, barring gross negligence on the part of the exam board. Seeing the amount of people who'd answer 1 when the intended answer was 9 would revise an instant rewrite of that question.
Edit: Post formatting doesn't really allow for the extended fraction divisor in the second example.
Edit 2: fixed it.
It's all down to numerical precedence surely? You can't suddenly change the 'rules' overnight. So, based on teachings in the 70's and 80's the equation would reduce to 3(3) which is 9.
Surely if they wanted it like the first example they'd write it:
6
-- (1+2)
2
If you get the drift of my formatting.
Did resolving the brackets not take precedence in the 70s?![]()
Edit:
I get ye, but I formatted it wrong - the line equation was the format in question, and should have gone first in my post. Your display is exactly the same as mine, only shown better, but they both lead to the same line equation, qhereas yours cannot be analogous to my second fraction equation.
Yeah so that gives you 6÷2x3 and you work from there
Ultimately if this expression appeared in any practical application, you would already know whether 2(1+2) was considered as one term or not from previous calculations.
