Again, you're being pretty ironic here Hatter as I think the major problem at this point is that you can't consider those with greater scope for perception on this matter than you have firstly that the training wheels that is PODMAS, or whatever you call it, taught in primary or secondary schools is not infallible and is intended to help children proceed through equations that would never be as badly worded as the initial one and is not something that would constrain more 'serious' practitioners of mathematics.Just because you do not know or understand something doesn't make it universally ambiguous.
Or is everything you don't know universally ambiguous?
Secondly they say the equation is intentionally ambiguous and the fallacy trap that it wants people to fall into is not saying either '1' or '9', it is saying that it is definitively one over the other, which again you refuse to comprehend. Previous solutions to make it to '1' have been given even though you have repeatedly asked for them. As already said too, those 'in the know' have also said they would lean towards '1' on first inspection, myself included, over '9'. Maybe some introspection is order here.
To try and put this into context, very basic educative books on astronomy and the alignment of the planets have done and probably still do list Pluto as a planet, maybe in the form of "My Very Easy Method Just Speeds Up Naming Planets" or something similar. Recently scientists have determined that very technically it is not, and is actually a sattelite rather than a planet. Does this mean the scientists are wrong since the apparantly infallible education system decided to print this in their books? If books continue to list it as one, does that mean the 'MVEMJSUNP' moniker intended to help children is an odious lie?
No, it means that bridges are often made for a greater good in education to help children make connections in complicated subjects easier, and that knowledge is ever-changing and coming out of a secondary-school assuming you are grounded infallibly in a subject is very, very wrong.
Think about it a bit.
"No you think about it a bit!!11"
Well, at least I tried...
Looking at Nitefly's signature I think Orwell should have said that freedom is the freedom to say that 6/2(1+2)=1.
Either you are trolling or you are stupid.
I used a fx83gt calc....
When it is written:
6 divided 2(1+2) the answer is 1.
When it is written 6/2(1+2) the answer is 9.
Ambiguous notation is ambiguous.
/thread.
As much as I intensely dislike purposefully obtuse simultaneously infallible and unprovable theories too, that's another question for another day.Oh right, another one of those fluffy modern ideas that no-one can be wrong (no offense intended)?
It's all down to numerical precedence surely? You can't suddenly change the 'rules' overnight. So, based on teachings in the 70's and 80's the equation would reduce to 3(3) which is 9.
I can see how 1 can be the answer but that's only possible if the accepted order of precedence is changed compared to the accepted standards of the past.
You just ran through exactly the same thing twice but got different answers.Nice, resort to personal attacks when someone disagrees with you.
I don't have a division symbol on my KB, so I assumed you were intelligent enough to know I was referring to the OP's way of expressing it as opposed to the second example. I have added the explanation for you in the relevant post.
Something I clarified later anyway.
When it is written:
6/2(1+2)
6/2(3)
3(3)
=9
You do the parenthesis first, then the divisions/multiplications. How can it be anything else?
Yes, but only because the English word implies a new grouping:
6 divided 2(1+2)
6 divided by the result of 2(1+2)
6(2(1+2)).
And which 'OP' are you referring to?
Thread title: 6÷2(1+2)
Poll question: 6/2(1+2)
When it is written:
/thread.
My point is and always has been that the "solutions" arriving at 1 are wrong, because they are not following the standard order of operations.Secondly they say the equation is intentionally ambiguous and the fallacy trap that it wants people to fall into is not saying either '1' or '9', it is saying that it is definitively one over the other, which again you refuse to comprehend. Previous solutions to make it to '1' have been given even though you have repeatedly asked for them. As already said too, those 'in the know' have also said they would lean towards '1' on first inspection, myself included, over '9'. Maybe some introspection is order here.
