I made it up. If there was to be a logical definition, that's it.
You can't just call 2(1+2) y and then sub in y. Can't you see that is different?
My point was to demonstrate that this is the logic that dowie used for the 9÷3÷3 question.
Guys, if an aeroplane is on a treadmill that accelerates at the same speed as the plane, will it take off?
I've not - I'm applying the same rule to both
'/' or '÷' just applies to the next term
9÷3÷3 can be written as 9*(1/3)*(1/3) = 1
or in the instance of the OP
6÷2(1+2)
can be written as 6*(1/2)(1+2)
Without wanting to repeat myself too many times - this is simply a question of the defention of the operator '÷' or '/' - believe it or not they have been used before and this problem has been considered before.....![]()
Incorrect.
3x = 3(x) = (3)x = 3*x = 1*3x etc.
At least we could test that.
Also, isn't the answer no? There is no lift if the plane is still.
There is a big difference between equivalence and simplification
does an apple = a pear
if
an apple = a fruit
and
a pear = a fruit
*sigh* - it's gone over your head again. Ok, I will break it down for you even more. What is your solution for this one:
1*9÷1*3÷1*3
Unfortunately you seem to have closed your mind up and that is why you are repeating yourself.
1*9÷1*3÷1*3
You have deviated from basic algebra to the metaphysical.
The answer is yes, there are plenty of youtube videos
YouTube videos of a plane on a treadmill? This I gotta see.
FWIW the answer to the above is 81
Without wanting to sound like a broken record
1÷2x is the same as writing
1
- * x
2
and it not the same as writing
1
2x
That is how '÷' or '/' works and is what people are essentially arguing about within this thread.
Thanks, that's all I needed to know. To even have the arrogance to provide a single solution to that mess of algebra has told me all I need to know about the type of person I'm talking to.![]()
