Driver issues
I updated to the latest drivers a few days ago, the ones that come with the new AMD vision engine control centre.
Apart from, it doesn't work.
When I run it, I get the error message saying the CCC host application has stopped working.
Obvious solution was to uninstall and use an earlier driver. So I uninstalled, downloaded the 10.8 suite, uninstalled again using device manager and then ran CCleaner.
This time, it didn't even install at all! An INF file was missing or something
So I unistalled using device manager, deleted all files I could find and ran CCleaner again. Then used windows update to get me of the standard VGA driver and installed the 11.4 suite ontop, section by section. Install driver, wait for windows to catch up, restart, install control centre, wait for windows e.t.c..
And now I'm back to square one.
Google has failed me, so the next step is to ask the internet. Lend me your wisdom OCUK!
I'm running this system:
5870
965BE
crosshair IV
4GB Ram
Windows 7 64bit
The problem is even more frustrating as it means I can't use the CCC to change my monitors out of clone mode, seeing myself type the same thing twice isn't a good use of power really...
5870
965BE
crosshair IV
4GB Ram
Windows 7 64bit
