Post #1239
Successful troll is successful
The original troll posted a facebook poll about it.
Last I checked it was over 88,000 posts and increasing.
Best troll I have ever seen
Post #1239
The answer would be different if there was a multiplication sign between the bracket and the second term as you would be calculating from left to right.
Maths-wise anything from functional analysis and differential geometry through to optimisation and machine learning. The stuff I've been involved in applying that to I can't be too specific but the company I'm in has had or has contracts with the Ministry of Defence, energy sector companies and the European Space Agency (ESA). I've done stuff relating to all of those. It's slightly cringe-worthy but due to something I was involved with for ESA I can literally call myself a rocket scientistOut of interest, what sort of stuff do you do now?
. I do miss doing theoretical physics at times but now I'm doing applicable stuff, even when I'm doing abstract maths
Maths-wise anything from functional analysis and differential geometry through to optimisation and machine learning. The stuff I've been involved in applying that to I can't be too specific but the company I'm in has had or has contracts with the Ministry of Defence, energy sector companies and the European Space Agency (ESA). I've done stuff relating to all of those. It's slightly cringe-worthy but due to something I was involved with for ESA I can literally call myself a rocket scientist. I do miss doing theoretical physics at times but now I'm doing applicable stuff, even when I'm doing abstract maths
If I recall you are only in your mid to late 20's, yes?Problem is, without knowing the expression writers intentions, you might get the "right" answer to the wrong question.
I find it hard to believe you were given a question where you needed to use the 'left to right rule'.
24÷3÷2 would never be written by anyone semi-numerate.
Christ almighty. Disagreeing with you about maths would be like Delboy telling Richard Branson how to run a business. Doesn't stop them from trying though...
Anyway, if bodmas is not a convention, or is not applicable even in such a simple problem as the OP posted, then WHY TEACH IT?
Because it is easiest to teach simple rules. Most students will not need to know any more than that, those that do just have to learn that it is simplified.
Same reason GCSE students are told the electron structure of an atom, only to find out it is a simplification at A-Level, and then to find out again that that was a simplification at degree level.
But surely it's easier to not teach a rule that doesn't exist at all than to teach a rule which is wrong.
Maths avoids ambiguity - there is only 1 right answer to a question. The answer isn't necessarily 1 number (e.g. root 4 is either -2 or 2, but "-2 or 2" is 1 answer - they are both simultaneously correct). Why would maths be left in a way in which such a simple question can have more than 1 different answer? That is why the 'left to right' rule is taught, and not only at primary schools - by Maths lecturers in Universities.
Firstly I think it might be called something else in other countries. I say this because someone posted a YouTube video or picture whose title uses a different acronym to BODMAS.Poor guy had never even heard of bodmas...
Sure, if someone doesn't give you an answer which you feel is appropriate then you should enquire further. But there's a fine line between healthy scepticism and just denial. One of the hallmarks of being intellectually honest and rational is being able to say "Okay, you've given an answer and I admit I do not understand it. As such I will accept your answer is the view of those in the know but I cannot wrap my head around it".Second is that anyone should feel unjustified in questioning or debating with a person of greater learning than themselves. Even the most academically brilliant person isn't going to know everything, or have perfect recall of everything they've learned.
FoxEye;19026708Anyway said:It is useful and applicable and its the thing which becomes second nature. I would never write 1/2/3 because I instinctively feel there's something wrong with that. However, humans are fallible and in my experience whenever someone puts down something which doesn't immediately and obviously have a clear meaning you have to ask them because the mistake they have made might not be what you think they have done, as that assumes they are thinking in the same manner as you.
Infants are the ones most likely not to explain themselves and not to write things following rules older people have more experience with.It's not like we're saying "bodmas works with infant level math but no higher". The problem posted _was_ infant level math, so if it doesn't work there, surely it shouldn't be taught at all?
If that expression, somehow, appeared in a mathematics paper then you'd have the line before and the line after and so you'd know what it meant.
Like what?There are still questions here I don't feel have been answered.
I seriously don't see the point in people investing time trying to decipher what is basically an expression someone has deliberately constructed to look dubious. If such an expression appeared in a paper submitted to a journal it would be flagged for confirmation and a comment made about poor notation. The reviewer wouldn't spend a week searching for a particular rule to use to interpret it. This is because a paper should be easily readable (when aimed at the appropriate audience) and a good reviewer will point out everything from poor grammar through to dubious notation right through to fundamental flaws making the paper worthless. And then we're back to the 'someone should be willing to say "I'm wrong"' thing.
And which rule is that? My first instinct is to scan through expressions right to left as it is often easier to compose functions and matrix operators in the manner and to understand the effect of linear operators on their arguments (like a sequence of matrices applied to a vector).That is why the 'left to right' rule is taught, and not only at primary schools - by Maths lecturers in Universities.
Mathematicians at universities have bigger fish to fry than trying to decipher poor notation. A rule often used in marking is that if it isn't clear what you're trying to say then you don't get the mark. Despite the stereotype, for mathematicians (as well as anyone else) there is a mild important on being able to communicate your thoughts clearly. Very few mathematicians in history have warranted another sifting through their work (typically after their death) to decipher their work. Some kid writing primary school level expressions doesn't make the cut.
The so called 'primary school left to right rule' is used in degree level maths
24÷3÷2 for example highlights the point. What would you evaluate the answer to be? Without the left to right rule, you could easily get 16.
Depends what you mean by physics. I often do stuff which describes physical systems but I don't do physics in the sense of hands on experiments.Sounds like interesting stuff, was wondering if you were doing any physics stuff, but from your reply I guess not.
It happens to a lot of people, particularly in the way degree maths differs so much from school maths in its form and structure. Continues on pass degree too. Some of the people I did my PhD who had been really enthusiastic initially realised within a year that they weren't enjoying it. Something about the gear crunching change in a pace from learning about the life works of 50 geniuses every course/term to suddenly being faced with a problem you have to solve which can't be looked up in a book.I thought I loved maths as far as A-Level, but my degree just drained any enthusiasm I ever had for the subject.
long explanation
Well, that's good enough for me.
It's not admitting I was wrong that's going to upset up; rather admitting that gambitt was right
That's like being KO'd in the first round by a midget in a dress!
What are you doing now? Something vaguely maths related or did you get put off it enough to not want to do anything mathsy?
