- 11 May 2006
You can noticeably tell the difference with classical music as there is so much going on. It is not a major difference though. This is with an external sound card going to my hifi or Goldring DR150s
You need to do an ABX test in order make any worthwhile claims.
The brain is basically an incredibly complex sound processor and can change your perception of sound drastically depending on your physiological and psychological state.
I was once almost certain that there were noticeable differences between two files of the same song, untill I found out they were bit for bit identical.
