Having recently purchased two MSI 6950's (flashed to 6970) for use in a P8P67M-PRO motherboard I'm struggling with temperatures and fan noise levels. With the cards mounted next to each other in the PCIE x16 slots, the temps on the primary card are uncomfortably high (~75 idle / up to 94 loaded) which is causing the cooling fans to run at 50%+ which in turn is generating significantly more noise than I would like.
I've moved one of the GPU's into the x4 PCI slot to give the primary card a bit more breathing room but this has not reduced the loaded temperatures by much. When benchmarking or running something like Crysis 2, I'm still hitting 91-92 degrees on the primary.
My question therefore is can anyone recommend a better cooling solution bearing in mind that this is a Crossfire setup so physical space looks like being a potential problem. My primary focus is on noise reduction but having invested in a pretty powerful system, I don't want to compromise on performance too much so would like to avoid under clocking if at all possible.
Note that with the original 6950 BIOS, running at factory clock speeds, the temperatures still push 90 degrees under load.
I'm willing to consider water as well as air solutions and am willing to throw some cash at the problem. If I cannot improve the noise levels significantly, I may end up selling one or both of the 6950's and going for a 6990 instead.
System specs
Intel SB Core i5-2500K CPU (@4.5GHz) (Hyper 212 cooler)
Asus P8P67-M PRO Motherboard
2 x MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card (Cat 11.4 drivers)
Corsair HX 850W ATX Modular SLI Compliant Power Supply
Fractal Design Define R3 Midi Tower Case
G.Skill RipJawsX 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz
Any and all suggestions gratefully received.
Regards,
System specs
Regards,
