- 22 Jul 2007
- nottingham
Got my Sandy and gfx cards on water which has turned a pc that sounded like a hoover to silent as a stick o ram and also great temps.
It's quieter but not hugely quieter certainly not as much as it used to be.
Bringing up gpu's with those leaf blower coolers is a bit cheap obviously those are very loud beasts but there's after market or better model cooler s with much quieter fans.
inaudible rpms ? 500 rpm is audible to me ? and that's not even blowing through a rad ? watercooling is quieter and cooler not disputing that What I am disputing is that there is still this massive gap in noise levels I just cant see logically how there can be.
My air cooler is capable of running a q6600 @3.6ghz 1.46 volts 24/7 with 1 fan at 500rpm the difference is that air cooling can do the same but lower temps.
These new massive air coolers are superb as the OP has pointed out.
Because watercooling used to be a lot quieter than air cooling which isn't the case anymore.
Makes me laugh when people think watercooling is quieter erm how can 2 or 3 x 120mm fans on a rad be quieter than say 1x140mm fan on a heatsink ? It's more about extreme overclocks and cooling performance these days.
i have a pair of GTX 480s, if they were on their standard air coolers i would have thrown them out by now.
may as well put the cpu in the loop too.
i am willing to bet my entire system that my computer is quieter than anything air cooled.
Soon there will really be no need for watercooling once all cpus are 32nm & the 28nm gpus are out.
I don't think the noise difference between air and water is that huge as people say.
Just because they are on a new node doesn't mean they will use less power, both CPU and GPU manufacturers traditionally target similar/the same power envelopes between process nodes (the power consumption/heat output of GPUs has actually been increasing fairly consistently for years now).
The next generation of chips will be just as hot and thirsty as the current generation, however they will offer more performance for it.
+1-If you think about it as the chip gets smaller theres less space between the eletronic components, so theres less air circulating around them to cool them, so the heat builds up.
