Crysis, worth £2.50?
5 Jul 2003
Atlanta, USA
Just seen that Crysis is £2.50 and the Warhead addon is £4.50 on Steam, worth a punt for £2.50?
And how will this system run it:
Q6600
4Gb RAM
GTX 285
Thanks.
What about the addon?
Essential, or am i better off seeing how i get on with 'normal' Crysis first?
Im hoping its more engaging than FarCry, which had me entertained for the first few levels then i got bored.:p
he he buying it now
op will run fine on your set up. maybe not maxed out but will still look great
is warhead a follow on? will i miss anything by skipping that?
Just buy both, they're not AMAZING games, but you'll get your money's worth
I already owned Crysis, bought it for yesterday for 2.50, so I could have it on Steam
Warhead, isn't an add on, it's a sequel to it
Worth getting both tbh
FarCry is the ONLY game I have ever played through multiple times and completed on every difficulty level.
Crysis is not as good, but a lot more showy.
^See I didn't like Farcry as much, I got so annoyed at the enemy being able to 'see' you when you were inside a tent
Are you poor?
what the hell. You spend all that money on a super computer and ask if spending £2.50 on a game that pushed pc gaming to new heights is worth it?
Q6600
4Gb RAM
GTX 285
Thanks.
i dont know how much crysis wars costs, or if you want it, but if its more than £7.50, and you do want to do the multiplayer, then i would suggest getting crysis maximum edition (crysis, crysis warhead and crysis wars) from a well known game etailer for £16.
if you dont want the multiplayer, then what your looking at is a steal
