Verdict
Note: Make sure you have the latest version of Crysis (patch 1.2) You'll know if you have it because there'll be a 'mods' tab in your main menu
I'm finally done
I've tried a whole load of different mods. The first number represents the visual benefit, 5 being highest, 1 no change. 2nd number represents the performance impact, 5 being a big performance increase, 1 being a huge decrease, 3 being no change.
Vanilla Crysis looks great. But if you're going to be playing it, please sacrifice 15-20 mins of your life to make it look amazing! Vanilla crysis simply doesn't fulfill the potential of the engine. There's 3 main places that the game falls down.
1.
Lighting - realistic lighting is something that is distinctly lacking in crysis, yet when it's done correctly it can make it look so real. There's loads of different TOD configs (TimeOfDay), so just go out and try them! I would recommend real lifesis, it's just stunning.
2.
Textures Certain textures in the game just aren't up to scratch. Need to grab the hi res foliage mod. If you have lots of Ram and/or GPU ram, then also get Rygel's texture mod, which adds some really great hi res textures.
3.
Optimisation Let's face it: Crysis runs like a dog
. Just grab yourself a config and it'll boost your framerates nicely. Should also improve visuals too. If you can run very high with reasonable fps, just grab yourself the extreme quality config. If you simply can't run very high, then there's plenty of other configs out there for lower spec systems.
If you've got the above, and still have a bit of system power to play with, then consider getting other mods as well.
I would recommend the extreme quality mod, but it changes gameplay very significantly, it's something that you'd probably want to play with after you've completed the game. I'll certainly be playing the whole game again with this mod as it's unlike anything I've ever experienced before.
I'm signing off now, my target is to make the best crysis screenshots I can
Rygel's Texture pack
4 2
Hi def foliage
5 3
Hi res grass
2 3
Custom Nano suit
3 3
Global ambient lighting
3 3
Extreme Quality Mod
4 2
Extreme quality config
3 4
Natural Mod
3 3
CCC Config
5 2
Real Lifesis
5 3
Xtreme particle chaos
4 3
