I got a reply from Hazro today, put simply they're working on the problems like the HDCP compliance on the WC and the nvidia compatibility problems and should hopefully give us some information on here once they have moreCertainly cheered me up to know that something is being done.
Yes, but if they do fix the problems with HDCP and nvidia compatibility in newer versions, does the included warranty cover such problems if you bought the screen now? meaning
will you be able to get a replacement without problems when the newer versions come out or will it be since you have the screen now, then you're stuck with the problems.
Actually, I might consider buying this screen again if they do fix the problems with HDCP and nvidia compatibility and if the nvidia software screen scaling options work the
way they are supposed to in allowing you to use a lower resolution without big black borders.
