MS Windows Malicious Software Removal Tool - May 2011 question....
2 Jan 2004
Chesterfield
On my (Win XP) netbook, I've downloaded the latest Windows update (I dont even look at what they are nowadays tbh!) and immediately afterwards, the "Microsoft Windows Malicious Software Removal Tool - May 2011" apparently detected an infection and asked if I wanted to run a scan.
I clicked yes and its launched into a scan and in about an hour and a half its done 75% of the scan and found around 5500 infections!?!?!?
I cant believe I have this many spyware/malware items on my netbook - I only reinstalled it about 2 months ago and its not used a great deal!!!
My question is, is there any way to check if this is a cosher Windows utility or some dodgy virus/spyware itself??
I've never had it pop up before but to be fair it could have been the latest update for all I know!?!? :confused:
Anyone had a similar thing happen today?
Should look like that.
Thanks guys - nice to know its not some dodgy software!!!
Bit worried though that its still running after almost 2 hours and has found 6900 infected files!!! :eek:
Great!!!! Took 2 hours and then froze on the screen where it says its getting rid of the infection!?!?! :confused:
Downloaded Spybot to see if thats any better!
Get MBAM (use freeware version, don't really need the realtime protection). If it's running right now you'll need to kill it in safe mode or use Rkill.
I ran Spybot and it found a dozen or so problems and got rid of them! Would you say I still need to run this MBAM??
I really cant be bothered to do a full reinstall - I dont use the netbook too much! ;)
Yeah deffinatly run malwarebytes, its the best one about.
Its best to update it then go into safemode without netorking and ran the scan
BTW did you not get a restore DVD with your Netbook as I did !
Used a external usb dvd rom drive for the Netbook.
Kenneth
Does everyone see that scanning window when the malicious software tool is downloaded? I've had that tool in dozens of updates over the years and never seen that before :confused:
You have to run it by going start/run/ then typing mrt
Windows Malicious Software Removal Tool x64 - May 2011 (KB890830)
Download size: 13.1 MB
You may need to restart your computer for this update to take effect.
Update type: Important
After the download, this tool runs one time to check your computer for infection by specific, prevalent malicious software (including Blaster, Sasser, and Mydoom) and helps remove any infection that is found. If an infection is found, the tool will display a status report the next time that you start your computer. A new version of the tool will be offered every month. If you want to manually run the tool on your computer, you can download a copy from the Microsoft Download Center, or you can run an online version from microsoft.com. This tool is not a replacement for an antivirus product. To help protect your computer, you should use an antivirus product.
More information:
http://go.microsoft.com/fwlink/?LinkId=39987
Help and Support:
http://support.microsoft.com
start pc pressing F8 and choose safe mode with networking
then go get malwarebytes and install and update
then let it update and scan
Remove all infections
Restart and away you go ( no need for a reinstall )
Sorry but imho do not do this!
1. Install Malwarebytes.
2. Update it.
3. Reboot to Safe Mode without networking.
4. Run a complete scan and remove anything found.
Safe Mode runs just enough to get Windows running so things like anti-virus and firewalls etc are not up and running so having networking enabled without them is risky imho.
Stoner81.
2. Update it.
Stoner81.
What
Dont be silly unplug the lan cable when finished installing if you are that paronoid or wear a metal hat lol
Or safe mode
Why do people think that they will get a virus as soon as the connection is established
I have run MANY pc's withought a antivirus and NOT got a virus,
