Looks good! I especially like the inclusion of my sub in the top corner. I was also very intrigued to see that it looks like someone has made a hole or put a block on the top of my sub, towards the rear. I will investigate that later on!!!!My house and deathcube behind Halfmad's lighthouse.
I know. I've made a whole load of it, I just need a few diamond pick-ax's to mine it all!You need to redo that sub in black obsidian![]()
need an udner ground one![]()
Have a look at this map, it's the latest version. You'll see loads of free space where you can build. There is some around the spawn area, but the further you move away, the more free space you'll find. When you find an area, have a good look around for any signs, walls or torches. This is generally how people mark out their areas to stop other people building there. If there is someone close by, also be aware of any tunnels that they may have dug.im hoping to be about tonight, just trying to learn the game and don't want to screw anything up.
Can anybody point me to a safe point to start building summat?
Barely had time to finish these before I had to head out to work, will render an underground one late this evening when I get home.
Probably not active enough to be whitelisted but thought i'd ask anyway. No probs if its not possible![]()
Already done thatsign up instructions in the first post
