Taskbar? plz explain/point arrows mate. I have not changed much on the taskbar...
do you mean the start orb?
also just noticed that it dont look like the theme has taken affect properly, did you restart/reboot after you patched the system before you applied the theme?
You are also missing...
But like I said, it took me a long time to get everything to work how I wanted with a lot of googling. The theme is called AaeroA, so the best I could do is suggest you look very hard allover the web
I have got Win7 Ultimate but I dont really think that makes a difference...
...I could be wrong though lol
Thank youFixed!Thank you
WooHoooo!!
Well done! I hope you enjoy your new theme![]()
My new queeze
Mine is very boring but I like things simple (just lke me.!)
Its rainmeter and its a mixture of different ones.
Weather, clock and wifi is from speed skin
launcher above the bin is from places skin
uptime from kotoko skin
Calender from lexis skin
recycle bin, notes and battery from razor skin
websites from omnimo skin
Icon are token icons
This is all from deviantart.com
http://browse.deviantart.com/?qh=&se...+skin#/d2qbg7x
http://peota.deviantart.com/#/d3c7hnv
