Nvidia GeForce Beta 275.27 - Performance Increases !!
Caporegime
8 Sep 2006
On Ocuk
GeForce Forceware 275.27 Windows 7 Vista x64
GeForce Forceware 275.27 Windows 7 Vista x32
GeForce Forceware 275.27 Windows XP x32
RELEASE NOTES
http://de.download.nvidia.com/Windows/275.27/275.27-Win7-WinVista-Desktop-Release-Notes.pdf
"Increases gaming performance by up to 12% for dual-core CPUs in CPU-limited cases."
Desktop Scaling
*New NVIDIA Control Panel user interface for configuring desktop scaling, including new preview window.
*Now consistently available for all displays (including VGA and HDMI connections).
*New scaling override option for Windows 7 gaming.
*Improved desktop resizing user interface that guides the user to disable overscanning using their HDTV controls and also provides a fallback option to enable desktop resizing via the NVIDIA Control panel.
*NVIDIA desktop resizing now creates a custom, resized resolution with 1:1 pixel mapping and resizes standard resolutions for games that don’t support custom resolutions.
FROM ANOTHER FORUM
The Witcher 2
All max, ubersampling off, and same settings.
270.61 WHQL: (11.8 fps)
275.27 beta: (47.3 fps)
More on performance:
Performance
•Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v270.61 WHQL drivers. The following are some examples of improvements measured on Windows 7. Results will vary depending on your GPU and system configuration:
GeForce GTX 580:
◦Up to 4% in Crysis 2
◦Up to 5% in Civilization V with SLI
◦Up to 9% in Portal 2
◦Up to 13% in Bulletstorm with Antialiasing enabled
◦Up to 15% in Batman: Arkham Asylum with PhysX High
GeForce GTX 560:
◦Up to 6% in Crysis 2
◦Up to 8% in Portal 2
◦Up to 14% in Batman: Arkham Asylum with PhysX High
◦Up to 15% in Bulletstorm with Antialiasing enabled
•Increases gaming performance by up to 12% for dual-core CPUs in CPU-limited cases.
I dont normally go for betas anymore but I think ill grab these after I have witcher 2 installed to compare them :)
They only do the major ones.
But you will see a gain in fps compare current benchmarks/ results when you get the new drivers.
Just installed these, seem to make BC2 run noticeably better and with less FPS drops, not noticed any temperature increases either. So far I'm liking these a lot!
(GTX 280 + Q6600 3.2GHz just so you know!)
