So, FTTC installed and working great!![]()
Good idea. xDThanks, but did you really need to quote the whole of my last post?
Does FTTC has some kind of training period, seems to be a bit of debate around as to whether it does or not....
This is my speed now, after about 6 my speed drop to sub 10mbs
My est was 32.5 and 8.5 up I sync at full speed.
Its worrying thefact you say it drops....... after 6pm?
Could be a REIN issue.
Did you get the Homehub 2 or the newer HH3 version? I'm just curious to see if the HH3 is actually out there already.
Oh right, I assumed you were d/cing and coming back on 10Mb for 6hrs![]()
Did you do the install your self? the wires and the face are not the ones BT openreach would install.
Edit: I see he didn't change the socket,
I have the same faceplate as you a brand new one and I also have an Austin Taylor one too, would it be worth me fitting mine instead?
I intend to. But i want one that is of good quality, not the 'standard' crap they use.. Know anywhere?Get a shorter RJ11 cable![]()
I intend to. But i want one that is of good quality, not the 'standard' crap they use.. Know anywhere?![]()
What is on the CD? I am concerned about what software is going to be installed on my mac?
eh? connection will be via ethernet or wireless. no software required.
