Caporegime
- 9 Mar 2006
- Surrey
Just finished the prologue, brilliant so far. Much, much better than the first. dialogue and characters are vastly improved.
I just got in from tescos, installed, and mine is doing the same![]()
Got my shiney collector's edition today afterwork, spent ages installing it and now it won't activate. I have quad checked the serial code and it stills says it doesn't exist!
HELP!!!!
Cheers
If your having problems with the codes try changing the 0 (zero) for O (letter). I had the same problem and this sorted it.
As for the combat it's damn hard, died so many times just trying to control the ballista at the start. It seems that you need to learn to pace yourself with the combat, get used to it's flow and you find combos/parries/signs/evading all happen with ease. I tried forcing the combat into a faster pace that i wanted and i died a lot, as soon as i slowed down it became a little easier.
BTW after you sort out the Ballista have a look around, Geralt makes a comment on something he see's. made me chuckle.![]()
'Actually its a Known BUG in 270.61, if you have the 3D vision driver installed Witcher 2 will run at 7 to 10 FPS on ALL settings, tested this myself.
Uninstall 3D Vision and it will work fine!'
How big is the collector's edition i ordered one but didn't turn up today and the post put a card in the door sayng there is a packet at the post office I'll have to collect :/ worry G*me have done there trick again and charged me for collector's edition and set me normal one again i'll have a right go at them if they have
actually there was an 0 which was an O![]()
Can't get past the dragon now . Is this game hard or am I rubbish!
