19 minutes here 1.3 mb/s.Ricky Gervais show is on in 30 mins too
There is an extra patch and some extras to authenticate and download so you could probly watch gervais as you set the game up and then jump straight in.
I feel for you,been waiting since 6pm,thought that was long enough.10 min for me... my god i cant believe ive been sitting here since 1pm ><
Finally got everything sorted, installed the beta nvidia drivers aaaaaaaaaaaaand the game is unplayable.
FPS drop ridiculously quickly, even on low.
Pretty disappointed so far.
By the way my game is running around 55-60 FPS where I previously left off in the monastery. 40 seems to be my minimum, and 60 max (I use Vsync forced on because it makes SLI smoother), but I cant alter the level of AA + AF somewhere inbetween the enabled and ubersampling options.
Both the lack of 16x10 support, and custom AA settings is
I cant find the forums for this game using google, does anyone have a link to them?
What card are you using?
SLI GTX 560s with 270.61 drivers and my I7 920 @ 3.8 Ghz is smooth as silk with 40-60 FPS.
I'm going to downclock my graphics cards now, I only OCed them after playing the game with ubersampling, but it made my room too hot, even though they are a lot cooler than higher end cards
From the guru3d forums: 'Actually its a Known BUG in 270.61, if you have the 3D vision driver installed Witcher 2 will run at 7 to 10 FPS on ALL settings, tested this myself. Uninstall 3D Vision and it will work fine!'
Download fraps?
Nope. I have tried and tried to play this but I just can't get past the horrible combat system.
It doesn't detect keys, fails blocks, doesn't dodge, etc.
There is pauses before and after each action, especially signs
Parry is pointless because it stuns you too, I end up just rolling around all the time.
The targeting is clunky and the "group" style is totally missing despite always facing multiple enemies
It's a bit random if you do a quick "quick" strike or some crazy spinning jump right into the middle of everyone.
I clearly fail at this game
For those using the 360 pad, is it possible to invert the analogue stick?
