- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
The popular Lamptron fan controllers are now back in stock and ready to ship today!
Lamptron FC2 5.25" Bay Fan Controller - Black @ £24.98 inc VAT
From the Lamptron design team comes the FC-2 fan controller! Designed from feedback from users like you, This device can control 6 channels that supports up to 45 watts each, CNC milled faceplate from blocks of 3/4" thick aluminium, and blue leds behind each knob. Smooth control of your fans for power at your finger tips!
- Dimensions: 5.25" Bay
- Max Power: Up to 45W per channel
- Colors Available: Black Anodized Aluminum, Plain Aluminum Finish
- DC Input: 12V(Standard 4 Pin Molex Connector)
- LED Indicator: 12 Blue LEDs 5.0V
- Fan Connectors: 6
- Fan RPM Knobs: 6
- CNC Milled from blocks of 3/4" Thick Solid Aluminum
- Normal Output 45W Each Channel
- Six 3-pin Fan Connections on Backside
- LED Brightness is Controlled by RPM Knob
Only £24.98 inc VAT.
ORDER NOW
Lamptron FC5 V2 5.25" Bay Fan Controller - Black @ £34.99 inc VAT
Lamptron listens to the call of users worldwide begging to change that boring white or blue LCD readout used in many fan controllers of today. With the Lamptron design team working closely with suggestions by users like you, we perfected a fan controller that allows a person to change the readout color of not one or two but seven different colors! We also added a function which allows users to choose what they desire to be displayed for the bottom line readout in the LCD display with the choices of Celsius, Fahrenheit, or Voltages. Now with new and improved LCD!
- Dimentions: 5.25" bay
- Power Output: Up to 30w per Channel
- Face Plate Color Available: Black Anodized/Silver Aluminium
- DC Input: +12v (Standard 4-Pin Connector)
- DC Output: 0-12v
- Changeable Display Color: Red, Yellow, Green, Cyan, Blue, Purple, White
- Control Channels: 4
- New and Improved LCD!
- CNC milled face plate from blocks of 3/4" thick soild aluminium
- Bring out that full aesthetic appeal you always wanted in the 5.25 inch Bay
- Four knobs to control four 3pin channels
- User's choice of displaying Celsius, Fahrenheit, or Voltages for the bottom line readout
Only £34.99 inc VAT.
ORDER NOW
Lamptron FC6 5.25" Bay Fan Controller - Black @ £29.99 inc VAT
The FC6 fan controller is a great alternative to those other boring fan controllers with single color displays. Control your fans in style of your choice of 7 different colors. It is designed specifically for today's mainstream fans and features a "up to 20 watts per channel" design.
- Power Output: Up to 20w per Channel
- DC Output: 0-12v
- CNC milled face plate from blocks of 3/4" thick solid aluminium
- User's choice of displaying Celsius or Fahrenheit for the bottom line readout
Only £29.99 inc VAT.
ORDER NOW
Lamptron FC Touch Fan Controller @ £49.99 inc VAT
The Lamptron FC Touch brings smart touch screen functionality to your fingertips for fan control. Control up to 6 channels in either manual or auto of your choice. Each channel can have its own independent automatic parameter in which you can adjust to your own specific needs. Each channel features up to 30w of output.
Pick your readouts in choices of RPM or voltage for one side, and Celsius or Fahrenheit for the other. Fits into a single 5.25 bay of your choice. All presented in a CNC milled faceplate.
- Faceplate Color: Black Anodized/Silver Aluminium
- Dimension:148.5mm X 42.5mm X 64.5mm (5.25inch bay)
- Screen Dimension:118mm X 31.5mm
- Power Output:Up to 30W per channel
- Control Channels:6
- CNC milled front panel
- Clean and streamlined interface
- Streamlined touch functionality to control your fans
- Choose between RPM or Voltages and Celsius or Fahrenheit for readout
- Set the channel in either Automatic or Manual control to control the fans
Only £49.99 inc VAT.
ORDER NOW
- Fan Connectors: 6
- Fan RPM Knobs: 6
ORDER NOW
- DC Output: 0-12v
ORDER NOW
- DC Output: 0-12v
ORDER NOW
ORDER NOW
