With help from you guys
7 May 2011
N.Ireland
With help from you guys I managed to Re-built my PC in a New case (Second time I've (re)built a PC)
I know cable management isn't the best around the PSU and SATA inputs but better than it used to be.
nice job, thing with cable management is just keep going back and you will kepp thinking of new placed to put them :) took me 4 hours to do mine! looks good though lol
Much better :)
I bring my 24PIN ATX power cable through to the back of the motherboard tray and up the hole next to the motherboard port.
You could potentially do the same with a few of your own cables! :D
+1 that is what i do too and it looks very neat :)
Looks better!
That cable that runs over your RAM, I'd try and bring that up around the back and down behind the radiator for your H50 to tuck it away a bit if i can't fit under the board and out between the mobo and the back of the case.
very nice! i've been into my own case 4 times to play hide the cable and that's just since i built my new rig on saturday!
