 - 5 Nov 2004
I am aprox 250 yards from the green box.
			You should always do or the line will sync to slower speeds as ISP's think your line is faulty as when you turn off it shows as line error or something that's what BE told me and it's true because i used to turn mine off every night getting slow speed but since leaving on 24/7 it always hits cap since.(the engineer who visited even said the same thing)
I am thinking of leaving BE for this too as they are taking ages to get fibre yet it says my line would ger 32/8 estimate which is brilliant for me.
What speeds do you get with well-seeded torrents? I still get around 2-2.5 MB/s usually during peaktimes, but it's been a fair few weeks since I downloaded anything.Ok, I'v only been with BT for 1 days so far.... but all my fears where misplaced.
Speeds are great. The upload speed has made a big difference to my online gaming experience.
The only bad thing is the torrent capping.... but I thought to my self I dont do that much anymore, other than the odd TV program so its not a big issue.
The home hub is easy to configure... slightly less advanced features than what I was hopping for (its basic) but its good.
No issues so far. Engineer who came round was very porfessional and did a very good thorough job.
What speeds do you get with well-seeded torrents? I still get around 2-2.5 MB/s usually during peaktimes, but it's been a fair few weeks since I downloaded anything.![]()
Sounds pretty much like me then. Not terribly bothered about that, it's better than the 25 KB/s I got with Virgin.Only downloaded a tv episode yesterday it was 1.45Gb and took about 20mins, going around 2MB/s....
Seems the torrent cap comes in at around 4.07pm
	JDownloader with files from fileserver appear to be downloading at 500k ish but if you download them in your browser they appear to be at full speed? Any ideas?
So im not the only one that uses jdownloader...![]()
any settings / advise to share regarding max speeds?
