- 9 Feb 2004
- The Planet Houston
I do loads and have never bothered with the swirly thing or vinegar.
The key is fresh eggs. I use Burford Browns and I test each one in a glass of water before poaching (looking for as close to horizontal at the bottom of the glass). If the round end tilts up too much it's a little too old for poaching and the white will go everywhere.
I pour boiling water from the kettle into a frying pan (metal with deep straight sides) so it's about an inch deep then turn on the heat and wait for the bubbles to appear on the pan surface. Then break the eggs in (start stop-watch) and give them 1 minute with the heat on gentle. Then the heat goes off...
If I'm doing toast then at 5 mins the bread goes under the (fully hot) grill. At about 8m30s -> 9m the toast is usually done and is then buttered, the eggs lifted from the pan and drained and served, with runny yolks.
