- 18 Mar 2008
Not sure if anyone has had similar problems, but if I put the two texture PAK files from Rygels and HD foilage pack in my crysis/game folder, they don't appear to update in the game itself and it uses stock textures. Must be doing something wrong somewhere, perhaps a reinstall will fix it. Reallifesis working fine though, be nice to find an updated version of the depth of field though, set to 2 it's too much, and set to 1 only seems to work in iron sight view.
PS thanks to Centurion for linking the HD foilage mod![]()
I have the same problem, not sure why, and thanks Centurion!
Now I just need to get it working.![]()
Here's the solution to get foliage and rygels working together:
1. Open rygel's textureupdate1 using winrar, also open the hi res foliage pak in winrar.
2. In the Hi res foliage pack, navigate the folders, until you get to the folder which contains folders like bush, trees etc
3. Navigate through these on rygel's texture update 1 too. (it's the same folders you navigate through.
4. Now, look at the folders that the two paks have in common. Delete the common folders from Rygel's pak.
Problem solved. The problem is created because both texture paks contain new foliage textures
