Been searching for a set of case feet for a while, wanted something to replace the retangular piece of kitchten worktop which my pc sits on as the 420 Rad just goes past my case feet by about 5mm. Case feet varied from the normal rubber feet £2.50 to custom feet £20 + with P&P on top. After a short while came across a set of 40mm Twin Caster Plate Fix with Brake + P&P=£8.25. Which l'll just mount on to my FT01case feet as they about 45x45mm pads and the plate on the casters are 38x38 with 4 x4mm holes for screws, l will just use self tappers. They should arrive tuesday, anyway here is a picture of them and they are black in colour.
Will put a picture up when the wheels are mounted, if anyone needs to put there case on the floor they should be just the job giving a good gap between the carpet and the bottom of the case about 54mm's
