Bitfenix pre sleeved cables
It should be fine as it's a direct link to the manufacturer themself. Not another etailer.:)
Yep, i have a few of the nzxt products as well, (24 pin atx extension, 8 pin atx extension, 3 pin fan extensions) and got a set off front panel pwr, pwr led, hdd led and reset sw cables on the way. The bitfenix cables look a bit neater though as theres no visible heatshrink on them. The braiding goes inside the connector.
I have these and they are very good miles better than the NZXT the braiding is more of a cloth type material which makes them very flexible, plus they are very cheap also compared to the overpriced nzxt.
I would like to show my interest too. I am waiting to kit my PC out again with pre-braided. I have some NZXTs now but I dont overally like the black heatshrink on them.
I wonder if Bitfenix are using silicone braided cable for these rather than just adding the sleeve to PVC wiring. These cables come have a silicone inner insulation and then a glass fibre braid fused to the surface. It might explain why they don't need heatshrink as they don't suffer with the unravelling that you get with braid over a discrete cable. Silicone cables are excellent with heat, smell gorgeous and are lovely and flexible.
I'd be interested in some Orange 24atx, pci-e extenders, 8 pin and possibly a molex or two.
