It's great that we are discussing building a PC for a game that is coming out. Instead of the console ported crap that any PC can run.
Amen.
As a reference:
I can max out shogun on a 480gtx at 1900x1200 with 4xaa and 16xAF. simply haven't tryed any more aa but I've not seen any indication of any slow down so I would suspect I could go higher. This is also with ultra sized units etc. Maybe it's because the 480 has 1.5gb ram.
Yet to plug my second 480GTX in so I shall maybe get fraps running and do some comparisons when I get around to it.
I would also agree with you, people are presuming these cards are more powerful then they are. I would suggest that if you can't max shogun you won't max BF3. BF2 required the top hardware at the time.
Can't use 4x 590 in SLI.
Tri is about as good as is worth it with 470s, you need to run at resolutions where they would lack the VRAM to perform well to get decent scaling out the 4th one.
Its the MSAA that kills the fps...
I too am playing it maxed, with MSAA off.
What cpu do you have? Im thinking of upgrading mine, and hoping it will help my 5870 perform better.
Will the new Nvidia card be out by the time this game comes out? I could easily buy another 570 but I would rather have a single card.
Will it be be dependent on Vram or just plain processing power?
I have a 4890 2gb and was wondering if its worth upgrading to a 5870?
I was just looking to be BF3 ready.
I don't game that much anymore but it would be nice to be able to play hassle free.
I have 4 gigs ram DDR2
Q6600 at 3.7/3.8
And a Vapour X 4890 2gib
I was just going to put a 5870 in there and hope for the best?
Also buget wise, I think I will get around £70 for the card as it is quite rare being 2gib VRAM and vapour X and then top it up to around £130/140![]()
