Yeah I has the DEF blur. I know what you're saying but i'd rather play the game the way it's meant to be played than just play in a blacked out screen using cloak and night vision to get around in the dark.
That's fair enough, completely down to personal preference
What do you think of the mod in daytime scenes?
sorry for the complete noob questions here, but im just after a little advice on what would be best for me. on the demo of crysis i get ~28-30FPS at best with everything on very high and AA on x8. my resolution is 1360x768. it can easily drop to below 25 FPS when im fighting.
i played the full game for about 2 minutes and my framerate was complete poo, so im updating to see if i get any improvement with version 1.21
i am planning on getting the high def foliage mod along with the extreme quality config to help that framerate go up a bit.
first question is, where can i download these (is crymod working yet or will i need to look elsewhere). 2nd question is do you recommend i get any other mod?
Here you go mate, I've just uploaded the extreme quality config:
http://www.2shared.com/file/0iCYGx53/autoexec.html
Remember to turn aa off as this config enables edge aa. If you get 25 fps in normal crysis, you should get a few fps boost with this!
ugh, this is going from bad to worse.
i've done what the install instructions tell me to do, but now the textures for some of the rocks are dissapearing. i am now in a very bad mood, and tempted to trade this thing in if i cant get it working
as for CPU and GPU, check my sig![]()
Just in the game folder should be fine.
It's strange, I got no performance change at all with the hi res foliage mod.
I'd turn v-sync off if I were you. I don't think anyone has ever played crysis with v-sync
Glad to hear that something is sorted![]()
