- 13 Dec 2006
- On the forest moon Endor
Looking forward to your picture updates tomorrow EVH
Hey guys. I've got some updates.. Will post pictures tomorrow if the weather permits.
@Dr House - looks good. Solid core is what you need, wouldnt say it's crucial to get low smoke zero halogen stuff but I did it anyway.
I think I used a shade over 1200m of CAT6 (iirc 4 boxes used totally and 1 partially used/spare) and that was because I was being liberal! I get comments from friends and visitors (mainly my mate the openreach engineer, that it looks like a mini exchange) I can't imagine what you'd do with 10 full boxes
For reference that's 2 48way patch panels, and a 16way for phones spread across 3 floors (if you include the roof/loft). Get 2 boxes and order more when you're running low. The stuff I got had length markings every foot, so you knew when you were almost out.
Thanks for the info. I will get a couple of boxes and the see how I get on.
Also did you run HDMI cables? I plan to run 15m HDMI cables to 8 points around the house and install a HDMI matrix which will be hooked up to a Control4 system.
http://cgi.ebay.co.uk/Van-Den-Hul-H...nnectors_RL&hash=item3cb7b61d24#ht_684wt_1109
EDIT, BTW the house looks very nice, good work!
Either HDMI over IP or an HDMI Matrix that runs on Cat6 would be better. There is definitely a 1x8 matrix about. (Plus cat6 for 15m runs is cheaper/more reliable and you'll be able to send the HDMI to any cat6 output).Thanks for the info. I will get a couple of boxes and the see how I get on.
I believe the HDCable version is just a rebranded GrandBeing matrix, however the HDCable version is apparently better. Read through this thread and especially post 8.Thanks for the info guys, I will find my self a better cable. I am going to run HDMI and CAT fix to the TV points to give me more options. I will probably use something like his
http://www.hdcable.co.uk/4x4-hdmi-matrix-hd-anywhere.html
http://www.grandbeing.com/product/MX0404 320.htm
anyway i will stop invading your thread now.
Gas pipe needs painting.![]()
The driveway confuses me, it looks like it'll hold 1 car? The wooden fence dividing it into your garden doesn't open?
But really nice finish!
looking great outside, quick question tho, why no step for the front door?? looks abit funny with a slope imo. It could cause some damp problems inside in later years.
I mean yes, it has a person sized gate, but not a way to get a car right round the back?
But if out holds 3 cars then it's no problem! Dodgy pics tbh!
