Don
- 20 Oct 2002
- In a house
Hi guys.
I upgraded to Windows 7 last night, and have found it much better compared to my previous Vista install.
I was, however, having issues getting drivers for my Belkin Wireless G Desktop card (3000uk version). Belkin do not offer drivers for this card on ANY 64bit os, and not beyond vista at all.
So, i did some digging, and managed to find that the chipset was actually Ralink based. Some further digging, and a bit of guesswork pointed me to trying a driver for a Ralink RT2500 card (with win7 64bit support) which installed without issue, and allowed me to assign the driver to the Belkin card.
This then worked perfectly!!
Brilliant. Great work on Ralink to keep driver support going on for so much longer than the other manufacturers. I also hope this might save some of you from having to go buy new cards to support win7 if and when you update.
Find out who makes the chipset, and then search for drivers from that manufacturer. Usually a bit of guesswork is needed, but you might be able to save yourself some dosh!
