OcuK B Grade????
  • Thread starter Thread starter B&W
  • Start date Start date
Status
Not open for further replies.
On a motherboard the only accessory I'd care about is the backplate. Sod the SATA cables I've got plenty of them, and the manual you can download online, but the backplate is the bit you want.
B-Grade = awesome. (obviously varies)
Got a 480 for £100 last week :p The box was a bit battered, but it came with everything but the molex<8pin, and demo CD's. Also came with an SLI bridge which I'm sure isn't normally included.
Should say what is wrong. If its packaging say 'This item is B-Grade because of Packaging' etc.
Just an idea.
Wouldn't really work if there was more than one of the item. It would have to be put up as a separate item, which I imagine would be a fair bit of hassle, for ocuk and the customers.
There is a competitor out there that has a series of tick boxes in 5 accessory groups. Would be worth implemening something similar.
Backplate: Yes
Boxed: No
Manual / Drivers: No
Other Accessories: No
Well, I looked at them, there are like 6/8 items so it wouldn't be long. If there are (xample) 10 with damaged box just put 1 ad, with 10 in stock, and say damaged box, then if you have another 2 with no screws, put a different advert up, with stock as 2, and write 'no screws'. Price will vary me thinks
thank you very much, looks like everythings there and looks in great condition, will definetly be purchasing.
Where are you looking? :confused:
I'll give you a counter example:
This has 10+ in stock, now it's possible that some are in damaged boxing, brown boxed, missing adapters, driver discs, etc.
Say it normally came with a DVI->Dsub & a DVI->HDMI adapter, and it was listed as brown boxed, but this particular one only had a DVI->Dsub; it'd have to be listed like that. Otherwise you might buy it thinking it had the DVI->HDMI when it doesn't. They probably wouldn't list it as not having either, because imagine buying it, then buying an adapter separate, receiving it and it having the adapter you just paid a fiver for.
It's a good idea, but I'm not sure how easy it would be to implement. I suppose one way could be to use the same drop down selectors in that the systems section use.
I got my U2410 from B Grade.
It rattles a bit, but works flawlessly. Cost me £315 when the screen was retailing for £450+. Dead chuffed.
Got a B grade mb 3 years ago.
Brown box only no extras but it was £150 instead of £250 at the time so i wasnt complaining.
Still running as my 2nd rig :)
What was up with the board.
cold boot problems, really picky with memory, erratic stability, and I've replaced so many things, every time I rma the board they say they've fixed it. I always get it back with the same/or new problem and they won't give me a new one.
Just having to live with it now tbh..
Status
